Multisim and Ultiboard
How to set BBM time Voltage Controlled SPDT Switch
Hi, I'm trying to use VOLTAGE_CONTROLLED_SPDT component from Multisim Lib, and I don't know how to set the Break Before Making time for this SPDT switch. Is it possible to set BBM time? If it is not, how can I make SPDT switch with BBM time approach? And does this VOLTAGE_CONTROLLED_SPDT have BBM time? Thank you.
(2,920 Views)
Hello Julius16,
As far as I can see from the UI of Multisim there is no available option that can address this issue but I would like to test some ideas that could do the trick and I will let you know my findings.
Now can you please tell me your OS version and the Multisim version you are using?
Thanks in advance for the response.
(2,877 Views)
Hi!
Thank you for your help. I'm using Multisim Education Edition Application version 14.0.1.f1 (14.0.1082) Database version 14.0.b on Windows 10.
I'm looking forward for your idea, and thank you in advance!
(2,872 Views)
