Multisim and Ultiboard
How to simulate an H-bridge Circuit with motor to see if its turning
I have the following circuit and want to know how I can simulate it to check and see if the motor turns. Newbie thanks23072i312CDCC13BAD66B7
(6,145 Views)
The motor used in the circuit is not an animate part, it won't show you if the motor is turning or not.   To test your circuit, you should use the scope and see if you get the right signal that will turn a motor.
Tien P.
(6,094 Views)
Поскольку в MS угловая скорость есть напряжение на валу электродвигателя, то можно засечь по пробнику напряжения поворот вала туда-сюда в вольтах-fv
(2,834 Views)
