05-13-2008 01:46 PM
05-15-2008 09:07 AM
Hi, well first of all, has your simulation time counter on the bottom right side of the application reach the 1 sec and 2 sec you are expecting? Remember that simulation time differs quite a lot from real-time. Is slower, so it might be happening that you have not yet reached 1 sec of simulation event after 40 or 50 seconds of our time depending on the complexity of the circuit.
Secondly, I would say that for the three points that you specify the TD_SWITCH might no be your best bet. The time delay switch has a fixed absolute time setting. You might need to use a different approach... you could:
