Multisim and Ultiboard
How to use commands like .save, .plot .print in multisim through netlists
Hi Yi,
This worked!! Thanks...could you also advise on two more things..
1. Is there a way to specify input waveforms through the XSPICE GUI?
2. Is there a way to invoke the XSPICE interface without having to invoke a GUI?
Priti
Message 11 of 13
(1,711 Views)
Take a look at this article:
http://zone.ni.com/devzone/cda/tut/p/id/4169
Even though it mentions Multisim 10.0, everything should still apply to your latest and greatest Multisim. We've added a few more variables and features to the analyses window, but almost everything is still the same.
I don't know of a method to invoke the XSPICE Command Line Interface without the GUI. However, you might have some good luck with our Automation API. You can read more about it in Help>>Multisim Help under the Automation API section in the contents tree. You need a programming language which supports COM to use this though.
Alternatively, if you just want to try something quickly, you can take a look at AutoIt:
http://www.autoitscript.com/autoit3/index.shtml
Good luck.
Yi
Software Developer
National Instruments - Electronics Workbench Group
Message 12 of 13
(1,681 Views)
Can anyone identify the differences between MultiSim GUI and the CLI... I am experiencing convergence issues with the CLI using the same Spice commands(and netlist) from the MultiSim GUI , which simulates with no problems.
Message 13 of 13
(901 Views)
