Multisim and Ultiboard
How to use the Transport Delay element?
Hello everybody,
I'm experimenting in Multism and I have to say that I am not an expert when it comes to eletronics. Unfortunately it's part of a project that I am involved in and I have to get to the bottom of it.
In my circuit I want to use a relay or voltage controled switch to simulate the distruction of a cable. To add the element of time I need this to happen at different times. Googeling this topic I found out about an element called "Transport Delay". So far so good.
Attached you will find my circuit. After using the switch J2 (A) i want the lamp to turn on and off about a second later. How do I change the delay time of this element?
If you have other smart solutions please do not hesitate to tell me, I would be very grateful.
Yours Luke
(5,877 Views)
Hello Ebra
right click on the component select properties and then modify the model parameters.
Hope it helps
best regards
Alexander
(5,862 Views)
