Multisim and Ultiboard
Howdo you correctly use 74247 BCD-to7segment Driver?
I am new to Multisim and I don't uderstand why my 7segment display is not lighting up.  I am using a 74247 even though it is obsolete (my school requires it).
(4,868 Views)
I am having the exact same issue. I'll look more into it.
(4,428 Views)
The 74247 has an open collector output, this means you need pull up resistors to interface it with the 7-Segment Display.
Add a 100 ohm pull up on each line between the chip and the 7-segment display to ensure your output from the chip is correctly transmitted to the 7-segment display.
Without the pull up the common anode display will not light up, once the pull up resistors are in place it should function as expected.
(4,423 Views)
