Multisim and Ultiboard
I have no interface
My problem is that there is no icon or menu in my interface, i have take an screenshot and you can see what the error is. Multisim workspace and Ultiboard has been working fine untill it crashes and i got an error message saying that Ultiboard stopped working and suddenly everything closed down. There is a ling to the screenshoot I have repaired the installation and also uninstall and install againg.
(4,368 Views)
Try this for me. Close Ultiboard (make sure it is not open), and delete the configuration file (config) for Ultiboard. To find the file (if you didn't move this file at any point in time), you need to follow this path:
C:\Documents and Settings\***your user name***\Application Data\National Instruments\Circuit Design Suite\***version***\config\.
So go to your C drive, then documents and settings, then to the folder with your username on it, then application data, etc, etc, until you reach the config folder. Delete everything in there and open ultiboard.
best of luck,
Miguel V
(4,330 Views)
