Multisim and Ultiboard
IR2117 Component wizard step 6 to 8 error
Hi!
How will I solve this difficulty as a student? I get an issue when I try to use IR 2117 in the component wizard.
First- the IR2117 is an 8-pin connector with just a 6-symble description.
What symbol will I use to adjust the lead assignments for the numbers 4 and 5?
Second- what does the second photo's message  means?  because the component wizard step 6 will not proceed. How will I fix this problem?
241856226_231077968961740_1914797742210359014_n.jpg241762429_539264404015289_4244518212955527245_n.jpg
Message 1 of 1
(1,617 Views)
