Multisim and Ultiboard
IRF7421D1
Hi, does anyone has the model of IRF7421D1, MC34082 ??
The model MC14013 its the same with 4013BP_5 in multisim?
(3,920 Views)
If you have the spec sheet for it there is always the possibility of creating the model yourself. That is what most people do when it is not included in multisim.
Matthew Trott
National Instruments UK
www.ni.com/ask
(3,899 Views)
Thanks..What about the MC14013 is the same with 4013BT_5 in multisim?
(3,890 Views)
If they are the same down to every possible configuration then it doesnt matter which you would use because they work on the same mathematical model. I suggest you double check that they are exactly identical and if not use the model for the part that you will be using when it comes to actually building the circuit.
Matthew Trott
www.ni.com/ask
(3,876 Views)
Thanks a lot
(3,872 Views)
I cant find the spice model for IRF7421D1 and MC34082????
(3,857 Views)
