Multisim and Ultiboard
Ideal Diode - in an rc circuit - virtual diode
I'm trying to do a circuit analyis in multism using a diode. I want to use the 'Ideal Diode Model' and the 'Constant Voltage Diode Model'.
Is there a way to adjust the forward voltage of the diodes? I'm trying with the virtual diode?
Thanks in advance
Nick
(3,297 Views)
Hi Nick,
Once you've placed the doide you should be able to double click it to bring up properties. One of these properties should be the forward voltage.
Jack
(3,247 Views)
