08-13-2013 03:39 PM
I have a customer pcb design in Eagle CAD, how can I import into Ultiboard?
I know historically this has been a problem, is there any new solutions or work arounds?
Thank you in advance!
08-14-2013 08:27 AM
No there hasn't been any updates on this. To the best of my knowledge, some customers have managed to output each specific layer from Eagle as a DXF that con be imported into Ultiboard. However I do not know how well this method works. You are free to try and we can always help if it's something on Ultiboard's DXF handling.
Kind regards,
08-22-2013 07:24 AM
We have the same problem. We have made hundreds of designs with Eagle (various versions over the decades) and now switched to Ultiboard. As far as I know, there is no suitable method to import Eagle pcb designs into Ultiboard. BTW this is more or less the same with other pcb/circuit design software, too. Most of them use their proprietary data structure which cannot easily be converted to a different one.
