Multisim and Ultiboard
Importing DXF (AutoCAD2011) to Ultiboard 11.0 removes curved traces
I'm trying import a DXF drawn in AutoCAD 2011 to Ultiboard 11.0.  My CAD drawing is a few different power divider layouts that include some different curves that Ultiboard doesn't seem to know how to handle when I import the DXF.  The main reason I want to import to Ultiboard is to be able to easily export the gerber files.
I was hoping someone could look at my DXF to see if Ultiboard is capable of recreating some of the curved traces I've drawn, because I haven't been successful with the conversion.  Also, since I only really need gerber files, is this the best method to obtain them, or is there an easier way that this can be done.
Any help is appreciated thank you. Attached is the DXF.
(3,393 Views)
I tried to import your DXF into Ultiboard 11.0.2 and it seems to look just fine. I have attached the Ultiboard design with this post. You should be able to export to Gerber.
Hope this helps.
Tayyab R,
National Instruments.
(3,377 Views)
