Multisim and Ultiboard
Importing .mod spice models
Hi to everybody.
I'm trying to import *.mod spice models into Multisim, but although all seems to work ok, when I try to simultate, the results are not correct.
For example, I've created a symbol for a INA111 Instumentation amplifier, and then I've imported the spice model (attached) from Texas Instruments web page. So, when I simulate a simple circuit consist of a diferencial input with a gain of 2, the output shows me zero volts and all seems to be ok in the schematics.
Do I edit the .mod file to import it to multisim?
I hope you can help me.
Regards.
(5,969 Views)
Hi Pelicar,
     I guess you have created a new component in Multisim using the Component Wizard (Tools>>Component Wizard) and the file that you have downloaded. If this is not the case, I would suggest opening the .MOD file with Microsoft Word in order to see the SPICE code clearer and paste this code in the Component Wizard. Here is a good tutorial on component creation: Creating a Custom Component in NI Multisim.
     Hope this helps.
David Oña
(5,906 Views)
Hi Pelicar,
It would be helpful if you could post a schematic with your INA111 component placed. That way we could pinpoint whether this is an issue with the component you created, or perhaps in the use of the component/surrounding circuitry.
There are already some INA111 components in the database (depending on the version of Multisim you have). If you want to update the model to be the Texas Instruments model, I suggest that you simply edit one of the existing components.
Hope that helps!
Natasha
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(5,886 Views)
Hi all.
Finally I found the fault. I was making a mistake in the mapping of symbol pins to model nodes.
Thank's to everybody
(5,868 Views)
