Multisim and Ultiboard
Inductor & lamp
hello
       Briefly.  I am a student working on a project.  I am trying to create  a light bulb  powered at 10W /15V.  After  choosing Sources -- Inductor and  Lamp the wattage  and voltage  mentioned aren't appearing for me to select to place in the work space.  I have tried typing this particular wattage and voltage in the  components area in the dialog  box.  When doing so it appears to be grayed out.  I am using Multisim  version 12.0.  If anyone kindly provide  me with  any advise.  Thank you.
(5,511 Views)
Hi Kelly,
Use the Virtual Lamp it's located in the "Indicators" group under the "Virtual Lamp" family.  You should be able to define the W/V for this part.
Tien P.
(5,471 Views)
