Multisim and Ultiboard
Installing Multisim & Driver Software
   Hello
  Briefly.  I am a new student who's been issued my class software.  In my software package I was issued 2 Dvd's.   First dvd NI Circuit Design Suite (Multisim) 12.0.1. &  the 2nd NI ELVISmx 4.4 Driver Software.  I am not sure which dvd out of the package to install first.  If someone could help.   Laslty can someone  also suggest a tutorial showing how install the driver software.  Thank's  in advance Kelly.
(5,860 Views)
Hi there,
Will you be using NI myDAQ or NI ELVIS hardware? If not, then you don't need to install the NI ELVISmx driver software. Simply run the Multisim installer and make sure you disable the NI ELVISmx 4.x feature.
If you have the the hardware, then run the Multisim installer, enable the NI ELVISmx feature. The installer will let you know when to insert the DVD for the driver software.
Fernando D.
(5,824 Views)
hello
       Thanks for your input.  I managed to firgure out what I needed to install.  All went fine.  Kelly.
(5,810 Views)
