Multisim and Ultiboard
Internal Program Error 1264
Trying to run the autorouter in Ultiboard and it has been working. Rearranged some parts to make the routing easier and now am getting this when I try to run the autorouter:
Autorouter[IC_console] 2010-11-01 15:51:05
Routing terminated due to an error
(3,175 Views)
Figured it out. I went through the entire design and one part at a time selected "autoroute selected parts" until I found one that caused the same error. It was a USB connector and D+ and D- were defined as a differential pair 'group'. But in the netlist editor I removed them from the group because the router couldn't route them as a pair (don't know why, was planning on figuring that out after I got the board to route with no restrictions). As soon as I deleted the differential pair group, the error went away.
Any chance the error messages could be made to be a little more informative? Radomly changing things to see if it affects it is a very time consuming process.
(3,160 Views)
