03-22-2012 03:51 PM
Hi, I am using mutltisim 11 and I wanted to create a schematic symbol for LM386 low volatge audio power amplifier. I was able to create the schmatic, but when I run the simulation this message appears: ------ Checking SPICE netlist for LM386_VoltageGain_10 - Thursday, March 22, 2012, 3:19:02 PM ------
SPICE Netlist Error in schematic RefDes 'u1', element 'xu1': Invalid subckt definition name 'u1_open_gain8'
SPICE Netlist Error in schematic RefDes 'u1', element '<unknown>': Due to errors, the subckt instance 'xu1' has been omitted from the simulation
======= SPICE Netlist check completed, 2 error(s), 0 warning(s) =======
Any suggestions??....I'm new to using multisim
03-23-2012 08:45 AM
I took a look at your circuit and it seems that you did not add a spice model for the component. You need a spice model to create a simulation component. You need to re-create the component. Follow the instructions in the link below:
https://decibel.ni.com/content/groups/circuit/blog/2011/04/06/component-creation-101
Hope this helps.
