Multisim and Ultiboard
Is it possible to make a radial keep in/out area?
The keep in/out tool allows for straight line segments only. Is there a way to place a circle as a keep in/out border? Thank you, Tod
(3,925 Views)
Hi Todc.18,
It is not possible to make circular or other shapes for keep in/out areas. They have to be polygons.
Tayyab R,
National Instruments.
(3,915 Views)
Thanks Tayyab, I managed to create ring shaped parts in the part editor. Problem solved.
(3,900 Views)
It is possible at use of import DXF.
(3,687 Views)
Hi supsup,
Unfortunately it is not possible to use a DXF import as the keep in/out area. I will pass on your concerns to R&D.
Tayyab R,
(3,669 Views)
You are right. I have not checked up function of an imported circle.
(3,662 Views)
