Multisim and Ultiboard
Is it possible to set up a Monte Carlo that will give me a set of stability factor plots for both K and Delta ?
When you run the Monte Carlo Analysis, you only have AC, Transient or DC to work with and looking through the available functions, I don't see how you can enter an expression that will give you K and delta.  Your only option is to use the network analyzer instrument.
Tien P.
(3,939 Views)
