Multisim and Ultiboard
Is there a way to draw on two layers at once? i.e. soldermask bottom and top
Is there a way to draw shapes on two layers at once? i.e. soldermask bottom and top. I need to cover holes with circle shaped soldermask on both the bottom and top with the same dimensions and if I could do both at once, it would speed up my process.
(2,994 Views)
Hi mastaprogramma,
This isn't possible with Ultiboard, but of course you can create the shapes and then copy and paste them to another layer.
I've added this to our freature request tracker so that it will be considered for a future release.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(2,953 Views)
