Multisim and Ultiboard
Is there a way to make a copper area in Ultiboard 14.0? The option seems to be gone
I have Ultiboard 14.0 Full edition (recently changed from 13.0) and it appears some options have been removed. I can no longer find how to add a copper layer as well as add a jumper. Have these been removed? I'm pretty sure these where on my version 13.0. I know for definate they were on the earlier versions I used.
"Everything should be made as simple as possible but no simpler"
(5,963 Views)
Accepted by topic author Lucither
Starting with version 12.0 of Ultiboard, all placed copper shapes act as copper areas. For example, if you place a polygon on a copper layer (Place menu > Graphics > Polygon) and open its properties by double-clicking the shape, you can access various copper area settings (net connections, voiding, fill style, etc) from the copper area tab.
As mentioned in your other post, the Full edition of Ultiboard unfortunately does not support placing jumpers.
I hope that helps.
Jeff
(5,917 Views)
