Multisim and Ultiboard
Isolation Amplifier in multisim 10 library
How can I get the component ISO122p in the multisim 10 library
(5,338 Views)
I do not know which version of MS you have, but in my Power Pro version there are a few simular types already there i.e ISO121G. Look under ANALOG>SPECIAL FUNCTION.
If you can't specifically use these , maybe you can modify one of them to the ISO122P parameters. This would definitely be a whole lot easier than  trying to create this from scratch.
I have not located a model for your specific IC so creating one from scratch or modifying an existing one could be your only option unlkess someone has already created on and wishes to share.
 Let me know if your version has these and if not I will post one of them for you to modify.
Also look at the website in my signature and see if there may be one there or request it on that forum and see if someone has one.
I hope some of this helps.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(5,319 Views)
Thanks a lot for your hint.
I looked the ISO 121G and ISO130 in the NI multisim library. They are different from ISO122P.
Modifying a component it is not an easy task. Mainly for me that never worked with SPICE. But I will tray anyway.
Have a nice day.
Mirofloripa
(5,281 Views)
