Multisim and Ultiboard
J/K Flip Flop - Divide by Two Circuit - How to Output Clock and Q?
Greetings!
Trying to create a very simple Divide by Two circuit, using a J/K Flip Flop.  Clock at 5V 500 HZ; 5V power in.
Can put a Voltmeter or Digital Meter (0/1) to generate a wave for the Clock, but cannot get anything to generate a wave from the Q output.
If I attempt to put any type of probe, nothing.
If I attempt to just truncate a wire at a junction, the wire is black/blue, not red like all of the other wires in the circuit.
How do you get the Q on a J/K Flip Flop to Output as a wave, to be able to compare the frequency to the Clock frequency?
I am trying to help students who have Macs use Multisim Live, as they cannot download regular Multisim on Macs.
THANK YOU VERY MUCH for any help or advice!
(4,918 Views)
Hi CFloyd,
You should have attached a screenshot of your circuit as it is hard to visualize what you created. I'll just proceed anyway.
A voltmeter or digital meter (maybe you are referring to digital/logic probe) cannot produce a clock waveform as they are measurement devices not generators. You should use a Clock Voltage Source, I think a Digital Clock is also available for Premium account.
A red wire signifies an analog node/net. Black/blue is for digital node/net, the two colors are for logic low and high.
For the input clock you simply put a digital probe or analog voltage probe in the interconnecting wire. For the output, you can place a Connector in your circuit and wire its terminal to the flip-flop's output. Through this wire. you can place a probe for observing the output. You need waveforms, not numeric displays that rapidly change, for your objective so you should open the Grapher window. You can click on the sine wave icon or the diode/sine icon for split-window mode.
One more important thing:
Multisim Live defaults to 3.3 V logic mode so you have to change it in Simulation settings which can be accessed by clicking on a vacant area of the schematic diagram then clicking the gear icon.
G. Goodwin
(4,865 Views)
Could you help with JK flipflop circuit me too ?
Here is an example - https://www.multisim.com/content/JTA3VhU2HMemByCRcuCWYe/jk-flipflop-with-clk-pluse/
Expected result is square wave on output.
Actually only constant values are available on output or sometimes simulation is just hangs.
Is it right way to create and simulate flipflop in Multisim Live ?
(4,834 Views)
Hi, GGoodwin!
Could you check circuit above ?
Looks like you have significant experience in Multisim Live.
Hope you know what is wrong with this design.
Thanks!
(4,804 Views)
Thank you for your reply and your help!
(4,774 Views)
Hi as_sk,
I already opened your circuit but I am currently using only a low-end mobile phone to access Multisim Live. It's usually difficult for me to run a circuit simulation that demands huge resources, your circuit will certainly complicate the problem (you mentioned that "sometimes simulation just hangs").
Nevertheless, if you are still interested, I request that you post this subject, including the circuit's URL in a separate thread. More problems may appear so it's preferable to give your circuit a separate space. If the circumstances will permit I'll try to work with your circuit. I am not an expert, I may not be able to solve your problem but I might be able to provide helpful observations.
G. Goodwin
(4,733 Views)
Hi, GGoodwin!
I've created new thread for this problem here
J-K-Flip-Flop-simulation-problem
Thanks!
(4,722 Views)
