Multisim and Ultiboard
JFET Curve Tracer Problem
Hello All,
I have tried everything to get this circuit to work, but it just won't cooperate. I put it on a breadboard and used myDAQ as a function generator and it worked just fine on an old Tektronics scope. Why won't this puppy run under Multisim? The URL for the design is: simple-circuit-turns-scope-function-generator-jfet-curve-tracer
-Barry
(6,020 Views)
Correction: h
@buzzbox wrote:
Hello All,
-Barry
 Correction:    http://electronicdesign.com/displays/simple-circuit-turns-scope-function-generator-jfet-curve-tracer
-barry
(6,012 Views)
Hi Barry,
Can you post your Multisim file, sometimes there is something in the file that is causing the problem.
Tien P.
(5,954 Views)
Hi Tien,
Thanks for your help. Here's the file.
-Barry
(5,947 Views)
Hi Barry,
It looks like the problem is R1, move it around and you will see the problem.
I replaced the Tektronix scope with the 2-channel, the B/A button is easier to access.
Tien P.
(5,927 Views)
Thank you Tien! It's always the simple things....doh!
-Barry
(5,920 Views)
