Multisim and Ultiboard
LED changes current value
hi,
i have connected a led with 8051 and wrote a simple C program for testing purpose. I found that the LED sometimes turns on and sometimes does not. I placed a probe and the probe reading shows different current values when i change the C program code.
For example,
when P20 = 0; in C code I get I(dc) = 1.21pA, V=300mV, V(dc)=0
when P20 = 1; I get I(dc) = 324uA, V = V(dc) = 1.76V
measured at the port's pin
The LED current setting is 5mA(the default). Is this peak to peak? or RMS?
The 8051 has source current capability of 60uA as I have come to know. Can we check this?
(4,578 Views)
Hi sumalama,
What version of Multisim are you working on? Can you upload the test schematic that you were doing with the C program?  For the 8051 sourcing capability you can take a look at the specifications of the controller, but I am a little confused with your description so in order to help you better I would like to see if I can reproduce the behavior that you are having.
Sil.VI
(4,553 Views)
