Multisim and Ultiboard
LM1496
I really need LM1496 in multisim but I can not make it
Who can help me?
http://148.202.12.20/materias/ET201/data_sheet/multiplicador/LM1496.pdf
Please help m,e
Message 1 of 21
(10,304 Views)
You can use the following models in Multisim that will give you the same functionality.
AD630:  Balanced Modulator/Demodulator
AD633:  Low Cost Analog Multiplier
The LM1496 is not longer available by its semiconductor manufacturer. However, if you need it just for the purpose of simulation and you have the SPICE model for it, instructions on how you can create your own component are in this link.
Mahmoud W
Message 2 of 21
(10,300 Views)
i have downloaded the spicee model for  1496 (attached), if working please tell me also !
dr_parjit@hotmail.com
*LM1496N 14 pins
*              +sig_in gain1 gain2 -sig_in bias out1 NC  +carr_in NC  -carr_in NC  out2 NC  V-
.subckt LM1496N    1      2     3      4     5    6   7      8     9      10    11   12  13  14
Q1 6 8 N001 0 CA3046
Q2 12 10 N001 0 CA3046
Q3 6 10 N002 0 CA3046
Q4 12 8 N002 0 CA3046
Q5 N001 4 3 0 CA3046
Q6 N002 1 2 0 CA3046
Q7 3 5 N003 0 CA3046
R1 N003 14 500
Q8 2 5 N004 0 CA3046
R2 N004 14 500
Q9 5 5 N005 0 CA3046
R3 N005 14 500
R101 7 9 1e12
R102 9 11 1e12
R103 11 13 1e12
R104 13 7 1e12
R105 13 0 1e12
.ends LM1496N
Message 3 of 21
(10,122 Views)
PLEASE CHECK IT IF WORKING PLEASE TELL ME ALSO ! dr_parjit@hotmail.com
Message 4 of 21
(10,116 Views)
I looked into the model and deleted some extra information. I have attached the modified model.
Tayyab R,
National Instruments.
Message 5 of 21
(10,090 Views)
Thanks for your quick and responsible response !
I am professor in punjabi university, patiala, (Pb) INDIA.
Please send me link for making this component 1496 on multisim. I was unable to do this even after reading how to introduce the ususer components.
Thanks  once again
Please keep in touch with me for you other efforts for multisim
Dr Parjit Sandhu
Message 6 of 21
(10,061 Views)
Here is a link to a component creation Demo. This should be helpful.
https://decibel.ni.com/content/groups/circuit/blog/2011/04/06/component-creation-101
Tayyab R,
Message 7 of 21
(10,043 Views)
Please send me link for storing this component 1496 on multisim in usuer database. I was unable to do this even after reading how to introduce the ususer components.
Please do it for me !
eagerly waiting for you response
Message 8 of 21
(10,035 Views)
I have created the component and you can save it to your User database by right-clicking and selecting "Save Component to DB".
The attached Code is provided As Is.  It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments.  You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
Tayyab R,
Message 9 of 21
(10,009 Views)
Thanks a lot, you have done a very good work for me.
Really it is very use full exercise
I am unable to find following components in  EWB.
  1. 566 for VCO
  2. 565 PLL
  3. 8038
  4. ADC 0804
Can I have spice model for these
Can I have equivalent to these IC ( please give No.), that exist in multisim
Message 10 of 21
(9,971 Views)
