Multisim and Ultiboard
LM339 Missing?
Hi - I'm an adjunct prof at a local college. In our text, we have an example circuit that uses an LM339. The LM339 appears to be available in the Academic edition but not the Student edition. Is there a library or config file that we can import to get access to the LM339?
(4,914 Views)
If someone can give you a primative in a schematic file, you can then use the "add to database" command to import it into that edition.  What version are you using? 9, 10, 11........It's important to know since the file formats are not forward compatible i.e. version 9 can not read version 11 files.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,912 Views)
Thank you for your reply. I'll give the database method a try. We're using 11.0. Also, I did a search for "LM339" at the kitmaster site, but there were no search results.
Mike
(4,904 Views)
My site would not provide that since it is a known part for the tiered software.  The site is about components that don't exist at all in NI's database.  Therefore, it would not be found there.
I've attached it here for this single part instance.
Good luck.
Chris
(4,900 Views)
