Multisim and Ultiboard
LM386 not included in Multisim 11.0.1?
Why are such common components such as the LM386 not included in Multisim 11.0.1?
Multisim is by far the best software of it's kind out there. I cannot understand why it doesn't have such common components included.
Many people (myself included) are not able to understand all the steps in the component creating wizard.
Message 1 of 8
(32,690 Views)
I found a SPICE model for the LM386 and created a simple tutorial on how to create this component in Multisim (for simulation only).
I also built a test circuit and the component seems to be working fine (see the file LM386.ms11).
Here are two more resources:
Creating a Custom Component in NI Multisim
I hope this helps.
Fernando D.
Message 2 of 8
(32,663 Views)
can any body tell me which labview vertion is supportid by multisim 11.0.1
Message 3 of 8
(31,214 Views)
Multisim 11 can support from LabVIEW 8.5 to LabVIEW 2010.
Tayyab R,
National Instruments.
Message 4 of 8
(31,199 Views)
how i can get FFT of a Circuit which is designed in multisim.....using labview 8.5......pls tell me sir
if possible then mail me full procedure....at sachinguptajazz@gmail.com
Message 5 of 8
(31,194 Views)
You will need to use the LabVIEW Multisim Toolkit.
Here is a page explaining the toolkit and how to use it.
https://forums.ni.com/t5/Example-Code/Automate-Circuits-Analyses-with-the-NI-LabVIEW-Multisim-API/ta...
Hope this helps.
Tayyab R,
Message 6 of 8
(31,178 Views)
Hi friend, I followed every step you gave but still the chip LM386 I built does not work on Multisim. Is there any testing I can follow to check what part goes wrong? Thanks!
Message 7 of 8
(28,320 Views)
atoms,
In this document: http://forums.ni.com/ni/attachments/ni/370/9159/1/How%20to_LM386.pdf  ,
step 12 is where most users get confused (this is the symbol - model mapping step).
If you have your component placed in a circuit, please post, and we can certainly look at it and verify what has gone wrong in the creation process...
Pat Noonan
Message 8 of 8
(28,304 Views)
