Multisim and Ultiboard
Labview controll using Multisim feedback
I would like to control a circuit in Multisim with a few simple analog and digital signals from a Labview VI. The circuit running in the Multisim simulation would generate analog and digital signals to be fed back to the Labview VI which would intern modify its control signals being sent to the circuit.
I have Labview 2011 and Multisim 11 but not NI's Control Design and Simulation Module. Is there a way to do simple circuit simulation with feedback without added software (modules)?
(5,400 Views)
 In V11, you can import a LabVIEW signal into Multisim by using the LVM source which is located in the Source group, and you can also export simulation data to LabVIEW through the grapher.  The feature you are looking to use is called LabVIEW Multisim co-simulation and this feature allows Multisim and LabVIEW to pass data back and forth as you run the simulation in both products at the same time.  This feature was introduced when Multisim 12 was released, you cannot do this in V11.
Tien P.
(5,373 Views)
