Multisim and Ultiboard
Load simulation settings is incorrect
Hello. I use the MS 10.0.343.
When I load simulation settings from a previous Parameter sweep - only some of the settings are correct.
The MS design is attached (see Cobra).
See JPG Simsettings_Correct. This is how it should look. I now save the simulation settings - and reopen:
See Simsettings_Load_Incorrect. Note that Device type has changed back to BJT. It should have been Vsource. The start/stop points for Vsource are correct.
Is this a bug or have I forgot something?
W.k.r.
(3,863 Views)
Some of the attatched files does not open so I attach them again. Hopefully it will work.
(3,850 Views)
Accepted by topic author SimpleEric
Hi Eric,
I was able to reproduce the problem your describing in 10.0.343. I checked in the latest released version (11.0.278 ), and it seems to be fixed in that version.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,833 Views)
