Multisim and Ultiboard
Long Copper Trace
I've setup a netlist with several componets connected to one copper area. The copper trace leaving the copper area to the componets takes the path to the first element in the netlist, which happens to be the furthest away physically on the board.  How can I have the copper trace leaving the copper area go to the closet components first?
tks, Terry
(4,016 Views)
Regarding your question which type of routing you used with this project? Because if you use the auto routing, maybe this is the best way to Ultiboard. Is there any chance that you can reorder the components on the board? Also, you can try route the traces manually.
Regards.
(3,944 Views)
