Multisim and Ultiboard
Looking for Multisim model of amplifier TDA7294
  Where I can find a Multisim model of amplifier TDA7294? If this model is unavailable so how I can make it? Thanks for any help. Best regards.
(7,723 Views)
what function this ic do?
Pradeep Kumar Achu
(7,722 Views)
The TDA7294 is a monolithic integrated circuit in intended for use as audio class AB amplifier in Hi-Fi field applications. TDA7294 contain a DMOS transistors, and can provide 100W of power.
(7,720 Views)
Hi Losrabinos,
  There is no public SPICE model for this type of amplifier. You should use a default OPAMP in Multisim or try the Vendors tech support, they might have SPICE model for it that you can import to Mulitisim.
David Varga
NIH
(7,659 Views)
