Multisim and Ultiboard
MCU: Metalink Assembler 8051 and LCD_Display_16x2 problems
I'm trying to  build the 8051 tutorial here:
http://www.8052.com/tutlcd
But I'm having problems in Multisim. I build the circuit and seem to wire everything up correctly, at least multisim doesn't complain, and the assembler doesn't mind my code, but it couldn't navigate to the build directory so I loaded the .hex file instead, but he LCD does nothing. I've attached the files, can someone please help?
(8,358 Views)
Accepted by topic author Laserbeak43
It seems ur beginner to multisim.
U must noteone thing.
Controlwords of the display module changes from manufacturer to manufacturer.
The codethat u have attached seems to be just copied from the website.
 To find the instruction bytes for the LCD given click info in the properties window of the LCD.
and some of the routines written for ur circuit are just useless
find the working file below. some modifications are made .
Regaurds
A.chaitanya
Message Edited by chaitu2 on 10-23-2009 10:10 AM
(8,254 Views)
Good job in making it work!
Yi
Software Developer
National Instruments - Electronics Workbench Group
(8,245 Views)
Regaurds
A.chaitanya
 Hi and thanks for the great fix! i'm suprised you used so few lines to make it work. i chose the 8051 and that LCD because it was used on that website(i was assuming the LCD was meant to represent that Hitachi 447xx). i ran it in a debugger and everything seemed ok, so i thought it would work in multisim. so, you click info to get documentation! 🙂 Thanks a lot for your help. Let's have a look at the code.... wow!! that looks so simple!! i can't believe i thought it was so complicated. so why would it be so complicated in that tutorial?
(8,237 Views)
glad to help:smileyhappy:
(8,221 Views)
