Multisim and Ultiboard
MCU Metalink Assembler 8051 with Windows 10
For every Assembler-Code I will get the following error:
Multisim - Donnerstag, 24. August 2017, 07:25:23
-------------------------Projekt Versuch1 wird erstellt-------------------------
main.asm
Fehler: main.asm
No listing file generated by assembler. (Invalid $INCLUDE directive? Semi-colon after $MOD directive?)
Assembler-Ergebnisse: 1 - Fehler, 0 - Warnungen
Every Programm starts with $MOD51, but it doesn't work.
Is there a solution for this problem?
(5,261 Views)
Hello Alfred 1969,
have you read the manual Multisim™ MCU Module User Guide on the following site:
http://www.ni.com/pdf/manuals/374486a.pdf
Regards
(5,231 Views)
Yes, I read the manual, but the asm51.exe doesn’t work under Windows 10 64 bit I think. The assembler doesn’t load the MOD51 File and so no list file is generated.
Yours sincerely
Alfred
(5,223 Views)
