Multisim and Ultiboard
MOSFET model SUP90P06
Can anyone please help get this model from VISHAY to work?
*Jan 2, 2006
*Doc. ID: 77342, S-52635, Rev. B
*File Name: SUP90P06-09L_PS.txt and SUP90P06-09L_PS.lib
.SUBCKT SUP90P06-09L 4 1 2
M1  3 1 2 2 PMOS W=16804728u L=0.25u
M2  2 1 2 4 NMOS W=16804728u L=0.45u
R1  4 3     RTEMP 3.4E-3
CGS 1 2     5800E-12
DBD 4 2     DBD
.MODEL  PMOS       PMOS  ( LEVEL  = 3           TOX    = 5E-8
+ RS     = 3.5E-3          RD     = 0           NSUB   = 1.5E17
+ KP     = 4E-6            UO     = 400
+ VMAX   = 0               XJ     = 5E-7        KAPPA  = 5E-2
+ ETA    = 1E-4            TPG    = -1
+ IS     = 0               LD     = 0
+ CGSO   = 0               CGDO   = 0           CGBO   = 0
+ NFS    = 0.8E12          DELTA  = 0.1)
.MODEL  NMOS       NMOS  ( LEVEL  = 3           TOX    = 5E-8
+NSUB    = 3.5E16          NFS    = 1E12        TPG    = -1)
.MODEL DBD D (CJO=740E-12 VJ=0.38 M=0.35
+RS=0.1 FC=0.5 IS=1E-12 TT=6E-8 N=1 BV=60.2)
.MODEL RTEMP RES (TC1=11E-3 TC2=5.5E-6)
.ENDS
(3,688 Views)
Hi cfmiteq,
This model seems to be working. I made a simulation only component and added this spice model and it seemed to simulate without a problem.
Here is a link to a demo which shows how you can create a custom component in Multisim.
https://decibel.ni.com/content/groups/circuit/blog/2011/04/06/component-creation-101
Hope this helps.
Tayyab R,
National Instruments.
(3,671 Views)
In step 6, how do I know what model pins correspond to G,S,D?
I was only able to get this model to work by changing
to
.SUBCKT SUP90P06-09L 3 2 1
(3,667 Views)
Hi cfmiteq,
In most models, they generally mention which pin corresponds to which symbol pin which makes it easy to map them. I was not able to find out exactly which pins map to which model pins. You will need to play around with it a bit to see which combination works in the appropriate manner.
Sorry I could not be of more help.
Tayyab R,
(3,641 Views)
I beleive I did, changing "4 1 2" to "3 2 1".
I am still confused how you were able to work the simulation without this change.
(3,637 Views)
