Multisim and Ultiboard
MOSFET modeling and SPICE language
I´d like to know wich levels of MOSFT modeling are supported in Multisim and if the spice language used is the standard one.
Have a nice day!
(4,345 Views)
Accepted by topic author Morara
Hi Morara,
You can find a list of the currently supported models/levels in the Multisim User Guide. You want Chapter 7 Multisim SPICE Reference > Analog Devices > MOSFET.
Unfortunately, there is no standard SPICE language. Multisim's implementation is based on XSPICE with some additions, however, Multisim supports compatibility modes that allows you use tell Multisim that a SPICE model was written for a particular simulator, and to use the syntax for that simulator. This can help use models designed for other simulators. As a general rule, if it is an analog model, it is likely to work unmodified in Multisim. If it is a digital model written for XSPICE, it is likely to work unmodified in Multisim.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,338 Views)
