Multisim and Ultiboard
MSM v9 lately has 5 second delays for all.
Multisim v9.0.155 has slowed so much that it is hardly worth using.  For instance, it takes 6 seconds to move a component.  EWB 4 was infinitely faster.  The rest of my computer system 2000 is OK.
Should I dump the application and reinstal from the disk?
Any suggestion will be appretiated.
Les Partridge sometimes called Lartlace.
(3,894 Views)
Hello, have you made sure your pc meets the minimum requirments.
If it does, are all the latest drivers and plugins etc up to date?
(3,891 Views)
Some other options that may help before you try a re-install. Do a virus scan and make sure nothing has infected your computer. Try defragging the hardrive. These are just a few simple thing to try. Also, you might want to look around in your Version 9 Folder and see if there is an uninstall program. I am not sure this existed in Version 9, but version 10 has an uninstall program that will allow you to effect repairs on it.
I hope maybe some of this can help
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,884 Views)
Thanks Lacy:  I used Settings / Control Panel / Administrative Tools / Defragment drive C and now v9 is running fast again ! ! !
Leslie
(3,857 Views)
