Multisim and Ultiboard
MULTISIM TO ULTIBOARD
Hey there guys,
I'm seeking some help for finding the proper dimensions and footprints when transferring from Multisim to Ultiboard, I'm having a really tough time finding the proper manufacturers to match the required footprints and dimensions that I need...
These are the measurements that I'm struggling with...
Resistors : Footprints:10.16mm Dimension : 6mm x 3mm
2.2 uF Capacitors : Footprints: 5.08mm Dimension : 7mm dia x 12mm height
10 uF Capacitors : Footprints: 7.62mm Dimension : 6mm dia x 3mm height
Those measurements will be evaluated if they're matching their requirement hence why I need to have them approximately.
I've got this circuit due for in a couple of days and I am completely stuck there so any help would be greatly appreciated!
Message 1 of 1
(1,848 Views)
