Multisim and Ultiboard
Matching components in Desktop Multisum vs Web based Multisim Live
Sorry if this is in the incorrect area, but I was wondering how to use the same components that are default selected in multi-sim for desktop.
For example, if I use the default op-amp 714 in the desktop app. It's a different 714 than the multi-sim live uses. I see there may be a way to adjust the values to mimic the one in the desktop version. But for my class, I can make sure I am getting similar values and for ease of use, I would like to know how to find the exact same one or one with the same values.
While writing this I see that the model option online has a version with similar values.
But how can I search using the search function in LIVE for the exact component model I need whenever this comes up? I don't see the model info in multi-sim 14 and the search function in LIVE I just don't seem to be able to find what I need. If you search 714 it doesn't bring up ANYTHING. Let alone a list of components with 714 in their model name...
(3,930 Views)
Accepted by topic author Ceroes
In order to achieve an exact model match, you need to compare their text models in spice syntax. and make them the same by editing.
(3,891 Views)
How would this be implemented in the web version of multisim? I don't see a way for how to edit the data?
(3,865 Views)
Ok I figured out where I can put the information but when I do I am still getting different values so I must not be doing something right?
This is the info from 14 I placed into the user-defined section. Yet I am getting -3.26V in the online version instead of instead of the 1.026V
.SUBCKT 741 1 2 3 4 5
* EWB Version 4 - 5 Terminal Opamp Model
* nodes: 3=+ 2=- 1=out 5=V+ 4=V-
* VCC= 15 VEE= -15 CC= 3e-011 A= 200000 RI= 2e+006
* RO= 75 VOS= 0.001 IOS= 2e-008 IBS= 8e-008
* VSW+= 14 VSW-= -14 CMMR= 90
* ISC= 0.025 SR= 0.5 Fu= 1e+006 Pm= 6.09112e-007
VC 5 15 DC 1.68573V
VE 12 4 DC 1.68573V
IEE 10 4 DC 1.516e-005A
R1 10 0 10Gohm
R6 11 0 100Kohm
R7 5 4 1Kohm
Rc1 6 5 5305.16ohm
Rc2 5 7 5305.16ohm
Re1 9 10 1839.19ohm
Re2 8 10 1839.19ohm
Ro1 1 14 37.5ohm
Ro2 14 0 37.5ohm
Ree 10 0 1.31926e+007ohm
Rcc 0 13 2.20906e-005ohm
Cee 0 10 1e-012
Cc 14 11 3e-011
C1 6 7 1e-016
GA 11 0 6 7 0.000188496
GC 0 13 1 0 45268.1
GB 14 0 11 0 282.942
GCM 0 11 10 0 5.96075e-009
D1 14 13 Dopamp1
D2 13 14 Dopamp1
D3 1 15 Dopamp2
D4 12 1 Dopamp2
Qt1 6 2 9 Qopamp1
Qt2 7 3 8 Qopamp2
.MODEL Dopamp1 D (Is=7.53769e-014A Rs=0 Cjo=0F Vj=750mV Tt=0s M=0)
.MODEL Dopamp2 D (Is=8e-016A Rs=0 Cjo=0F Vj=750mV Tt=0s M=0)
.MODEL Qopamp1 NPN (Is=8e-016A BF=83.3333 BR=960m
+ Rb=0ohm Re=0ohm Rc=0ohm Cjs=0F Cje=0F Cjc=0F
+ Vje=750m Vjc=750m Tf=0 Tr=0 mje=0 mjc=0 VA=50)
.MODEL Qopamp2 NPN (Is=8.30948e-016A BF=107.143 BR=960m
.ENDS
(3,861 Views)
Привет! У меня такой же результат получился. Нужно сравнить текстовые модели из обоих программ. (Мне не нравится мобильная версия, поэтому я ей не пользуюсь. Думаю, справитесь сами. Вы на верном пути)
Хотя, можно и в настольной версии получить мобильный результат, если напрячь мозги, и изменить один параметр в модели...
А, вот, почти идеальный баланс
(3,839 Views)
