Multisim and Ultiboard
Modelize Warburg element
Is there any way to simulate a Warburg element/impedance in Multisim?
Warburg element is an impedance whose expression is:
Z(jω)=AW/(jω)0.5
Where Aw is a constant.
Any idea?
Thanks for your time.
(5,637 Views)
You can use the Laplace component and type in your expression.
See attached circuit. I've set up in a voltage controlled current source configuration: I=V * H(s).
As such, the expression you enter into the Laplace function should be 1/Z(s).
This model will work well in AC analysis, but not in Transient. Run AC analysis and you'll see a plot of -I(V1), which is just the current going to this element.
Max
(5,620 Views)
I will try your solution. Thank you very much for your time Smiley Happy
(5,599 Views)
