Multisim and Ultiboard
Monte Carlo analysis
Hello:  My system, using MultiSim 11.0, doesn't do some Monte Carlo analysis properly.  It acts like the computer's memory may be becoming filled up.  And once a message appeared on my screen saying "Out of Memory."  And some "runs" are truncated.  Also some runs seem to have no ordinate values with the outputs overlaying the x-axis.
A different but similar circuit completed 15 runs.  The runs were for .25 seconds each.  The circuit is fairly simple including a 555 timer, some transistors, and passive components.  I can't show the circuit.
What could be the problem?
ronquan
(4,299 Views)
Hi Ronquan,
Select Simulate>>Analysis>>Monte Carlo Analysis>>Analysis Options, there is a field "Maximum number of points", increase this and see if  fixes the "out of memory" problem.
If changing the setting doesn't work, can send us the file?
Tien P.
(4,280 Views)
