Multisim and Ultiboard
Monte carlo analysis issue
Hi!
I am new to simultaion using Multisim. I am facing problem in understanding parameters in monte carlo analysis, when adding tolerance in configuration, if I select resistor in "Device Type" and have more than one resistor in my circuit then "Name" tab displays r2:xr1 or r1:xr2. What does it mean? Please explain.
Thanks 🙂
(4,861 Views)
Please help.
(4,852 Views)
Hi powerlab,
Here it is information about Monte Carlo analysis http://zone.ni.com/reference/en-XX/help/375482A-01/TOC134.htm and here it is a YouTube tutorial as well (it talks about Monte Carlo after minute 9:30) https://www.youtube.com/watch?v=n6B1OJXgDwk
I hope this helps you to understand.
(4,834 Views)
Hi Pedro!
I have already seen both, but still i am confused about the "Name" tab. Please consider that I want to apply monte carlo analysis on simple VDR network having two resistors r1 and r2 in series. In that case "Name" tab displays 4 options that are "r1:xr1", "r2:xr2", "r1:xr2" or "r2:xr1", what does it mean? Also, explain about "Present Value" tab, why it shows half value of resistance that is if r1 is 1000 and I select "r1:xr1" in "Name" tab then "Present Value" shows 500.
Your help will be much appreciated. Thanks.
(4,807 Views)
I am not sure right now, it seems to be something related to the circuit you are seeing or some configuration because I've tried to get those r1:xr1 and I haven't been able to. Can you upload this circuit?
I also recommend you to get the Monte Carlo example from Multisim -> Help so you can compare your settings and components with the ones there.
(4,797 Views)
Thanks Pedro!
I simulated the example circuit, and compared my circuit and parameters with it. It seems that I was using different model of resistor. I copied the resistor from example to my circuit and now i am not getting those r1:xr1 etc.
Thanks again 🙂
(4,791 Views)
You are welcome powerlab Smiley Happy
(4,784 Views)
