Multisim and Ultiboard
Mosfet Driver
Im trying to simulate a voltage source inverter, but am having trouble locating a mosfet driver. i know there is some on multisim but there not the correct ones. I would prefer IR21362 or IR2130, does anybody know how i can get these on to multisim.  i have seen some bodies circuit with the IR21362 chip but have no clue ow they got it there.  On the manufactures web site the Simulation models are in P-Spice.
Thank you
(10,028 Views)
If you could find that circuit with your Mosfet driver in it and can download it then you can save the component to your user database. If this was a picture that you saw, then you are stuck with creating one of your own. P-spice models will work in Multisim to a certain extent. You could try it and see. That is about the only way to know if a model will work.
I hope this helps some.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(10,023 Views)
I found there are several mosfet driver circuits under Misc devices.
However, I tried testing several of them and was not able to get any output from them.
I have attached a simple circuit, if anyone can figure out why the output of this TPS2819 does not work, I would appreciate knowing.
(9,878 Views)
Correct me if I'm wrong but I don't think there is a model attached to the mosfet drivers in multisim, in other words they are only meant for layout and not for simulation.
____________
/Peter Hygren
(9,868 Views)
