Multisim and Ultiboard
Mosfet Model of IPW60R045CP doesn't work
I try to simulate the Mosfet IPW60R045CP using the following spice model:
.SUBCKT IPW60R045CP_L0  drain  gate  source
Lg     gate  g1    8n
Ld     drain d1    3n
Ls     source s1   8n
Rs      s1    s2   1.5m
Rg     g1    g2     1.3
M1      d2    g2    s2    s2    DMOS    L=1u   W=1u
.MODEL DMOS NMOS ( KP= 112.533  VTO=3.85  THETA=0  VMAX=1.5e5  ETA=0  LEVEL=3)
Rd     d2    d1a    0.034 TC=13m
.MODEL MVDR NMOS (KP=272.45 VTO=-1   LAMBDA=0.15)
Mr d1 d2a d1a d1a MVDR W=1u L=1u
Rx d2a d1a 1m
Cds1 s2 d2 195.5p
Dbd     s2    d2    Dbt
.MODEL     Dbt    D(BV=600   M=0.85  CJO=88.84n  VJ=0.5V)
Dbody   s2   21    DBODY
.MODEL DBODY  D(IS=42.1p  N=1.08  RS=2u  EG=1.12  TT=750n)
Rdiode  d1  21    1.69m TC=6m
.MODEL   sw    NMOS(VTO=0  KP=10   LEVEL=1)
Maux      g2   c    a    a   sw
Maux2     b    d    g2    g2   sw
Eaux      c    a    d2    g2   1
Eaux2     d    g2   d2    g2   -1
Cox       b    d2   5.51n
.MODEL     DGD    D(M=1   CJO=5.51n   VJ=0.5)
Rpar      b    d2   1Meg
Dgd       a    d2   DGD
Rpar2     d2   a    10Meg
Cgs     g2    s2    6.81n
.ENDS  IPW60R045CP_L0
It doesn't work (no error message, but no current flow either).
Is there a way to make this model work?
(I am using Multisim 11.0)
Uwe Fechner
(5,538 Views)
I discovered, that the model works ok, but source and gate are swaped. How can I change this?
Best regards:
Uwe Fechner
(5,529 Views)
Hi Uwe,
I guess the problem is something because of the order of the Spice model nodes you assigned in the Component Wizard in step 4 of 8, when you build you userdefined component.
In your spice model it is written:
Lg     gate  g1    8n
Ld     drain d1    3n
Ls     source s1   8n
So you have to change the default pin parameters ( S/D/G) in step 4. Put a G  for Gate to the first postion and a S for Source to the third (last) position in the table. Then it should work correctly.
Regards
TomBaum
(5,519 Views)
your suggestion doesn't work.
Now I have a transistor, where Drain and Gate are swapped.
Is there anyway to swap the assignment AFTER the creation of a part?
I am trying to solve this issue now for half a year, and I am not successfull.
Best regards:
Uwe Fechner
(5,508 Views)
Accepted by topic author ufechner
I succeded in the end.
I had to edit the graphic symbol of the transistor with the symbol editor.
Gate and Source were swapped there.
Best regards:
Uwe Fechner
(5,505 Views)
