Multisim and Ultiboard
Mounting external source to traces
Hello all,
I am new to Ultiboard and am trying to do something that should be relatively simple.  I want to connect an external DC supply, which is terminated in ring terminals, to my PCB.  I can't figure out how to put in a hole that will connect to the trace.  It's a 6mm ring terminal, so I need a 6.2mm diameter hole.  I want one hole to connect to the input trace on top and the other to connect to the ground plane on bottom.
I can place holes in Ultiboard, but I can't connect them to the trace due to DRC; the copper area voids around the hole.
I can't find a hole in Multisim to put on the schematic to allow the DRC to recognize the connection.
In Ultiboard, the Through-Hole Pin option for connecting to a Net is grayed out.
Is there a way to do this?
-Nick
(3,995 Views)
Accepted by topic author nickdenniston
Hi Nick,
The hole is like a regular component in case and in the Multisim Master database there are no holes available so you will have to create a new component.   If you don't know how to create a component, please refer to the Creating a Custom Component in NI Multisim tutorial for more details.  When you get to Step 2 in the Component Wizard, select the hole that you will use in Ultiboard.
Once you created the hole place it on the schematic and run a wire to it, now you can forward annotate the update schematic to Ultiboard.
Tien P.
(3,973 Views)
