Multisim and Ultiboard
Multimeter outputs " -1.#IO TV " when using voltage controlled switch?
I just downloaded Multisim 11.0.1 and I made a circuit with a voltage controlled switch to simulate an ideal diode, but the multimeter is not working properly with it. The multimeter outputs " -1.#IO TV ". If I replace the voltage controlled switch with a normal switch, the results from the multimeter are okay.
voltage controlled switch values:
vt = 0.7 v
vh = 0 mv
ron = 0 pohms
roff = 99999 tohms
The circuit I made is in the attached picture.
(3,322 Views)
Can you upload the Multisim file so that we can easily analyze the problem.
Tayyab R,
National Instruments.
(3,314 Views)
