Multisim and Ultiboard
Multisim 11.0 Menu Items
Half of my menu items have disappeared from Multisim 11.0.  Please take a look at the image below:
In the image I included a snippet of a design to show I indeed have a design open, etc…  You might notice more than half of my menu items have disappeared!?!?!?  I cannot work like this.  I need to change the transformer in this design to a tapped secondary.  Before I change this particular design I want to “File”|”Save as…” this design and change the file name.  The “File” menu item, even though present, completely lacks all the file save sub-menu choices.
Do I need to re-install Multisim 11.0?
Steve Mays.
(3,682 Views)
Hi Steve,
It's likely that your user configuration file was corrupted. I suggest trying the instructions here: http://digital.ni.com/public.nsf/allkb/2719D00E36A4D53A8625721300685B3F. Just keep in mind that this will set your user configuration to the default- so if you customized the toolbars/menus in any way then they will be reset.
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(3,681 Views)
That fixed it!
Steve.
(3,676 Views)
