Multisim and Ultiboard
Multisim 14: FET component wizard error
Dear All,
I am having an issue with an ON semi model for a FDG1024NZ FET. I have downloaded the .lib file from the ON semi website, and used the Component Wizard in Multisim. I have created a 4 pin symbol for the device (based on post in this community stating that a 4 pin device should be used for a 3 pin subcircuit). When I attempt to advance the wizard page form for the model data, it incurs the following error:
"SPICE Netlist Error, element 'Bsim3:FDG1024NZ': Unsupported model type 'NMOS'
SPICE Netlist Error, element 'M_BSIM3:FDG1024NZ': Unsupported SPICE device type 'MOS7'
Do you want to continue?"
Is there anyone who can give me advice on how to import the NMOS and MOS7 models, and/or whether I need to modify the listing shown below.
Many Thanks!
.SUBCKT FDG1024NZ 2 1 3
** Fairchild Discrete Modeling Group **
** Website www.fairchildsemi.com\models **
** Scott Pearson scott.pearson@fairchildsemi.com **
** Chris Hanas chris.hanas@fairchildsemi.com **
** (C) Copyright 2009 Fairchild Semiconductor Corporation **
** All rights reserved **
** FDG1024NZ Spice model **
** Revision RevA, 17 Nov 2009 **
*Nom Temp 25 deg C
Dbody 7 5 DbodyMOD
Dbreak 5 11 DbreakMOD
Lgate 1 9 0.474e-9
Ldrain 2 5 0.1e-9
Lsource 3 7 0.547e-9
RLgate 1 9 4.74
RLdrain 2 5 1
RLsource 3 7 5.47
Rgate 9 6 2.17
It 7 17 1
Ebreak 11 7 17 7 22.5
Rbreak 17 7 RbreakMOD 1
.MODEL RbreakMOD RES (TC1=0.75e-3 TC2=-0.4e-6)
.MODEL DbodyMOD D (IS=0.2e-12 n=0.9 RS=205e-3 TRS1=2e-3 TRS2=1e-6
+ CJO=0.04e-9 M=0.6 TT=1e-9 XTI=1)
.MODEL DbreakMOD D (RS=30e-3 TRS1=1e-3 TRS2=1e-6 )
Rsource 7a 7 43.915e-3
Rdrain 5 16 RdrainMOD 91e-3
.MODEL RdrainMOD RES (TC1=3.6e-3 TC2=5e-6)
M_BSIM3 16 6 7a 7a Bsim3 W=0.12 L=1.05e-6 NRS=0 NRD=0
.MODEL Bsim3 NMOS (LEVEL=7 VERSION=3.1 MOBMOD=3 CAPMOD=2 paramchk=1 NQSMOD=0
*Process Parameters
+ TOX=240e-10 ;Oxide thickness
+ XJ=0.52e-6 ;Channel depth
+ NCH=1.32e17 ;Channel concentration
*Channel Current
+ U0=870 VSAT=200000 DROUT=2.5
+ DELTA=0.01 PSCBE2=0 RSH=43.915e-3
*Threshold voltage
+ VTH0=0.87
*Sub-threshold characteristics
+ VOFF=-0.1 NFACTOR=1
*Junction diodes and Capacitance
+ LINT=0.18e-6 DLC=0.18e-6
+ CGSO=720e-12 CGSL=0 CGDO=0e-12 CGDL=900e-12
+ CJ=0 CF=0 CKAPPA=1
* Temperature parameters
+ KT1=-0.6 KT2=0 UA1=11e-9
+ NJ=10)
.ENDS FDG1024NZ
(3,931 Views)
Hi tamsdon,
I found this forum, it is almost the same issue as yours. You can take a look at it for more detail explanations, but it seems that the solution was to modify the SPICE model as follows:
*Nom Temp 25 deg C
Dbody 7 5 DbodyMOD
Lgate 1 9 0.474e-9
Ldrain 2 5 0.1e-9
RLgate 1 9 4.74
RLdrain 2 5 1
RLsource 3 7 5.47
Rgate 9 6 2.17
It 7 17 1
.MODEL Bsim3 NMOS (LEVEL=8 VERSION=3.1 MOBMOD=3 CAPMOD=2 paramchk=1
*Process Parameters
*Channel Current
*Threshold voltage
+ VTH0=0.87
+ NJ=10)
.ENDS FDG1024NZ
Try it and let us know if it worked.
Jose F.
(3,904 Views)
Dear Jose F.
Thank you. I am very grateful for your assistance. I have just setup the part in Multisim part wizard and the spice model was now accepted. I will do more testing later tonight.
I am also having a similar issue with the following Intersil part, can you provide an insight with this file?
If I can help you with modelling issues in future, please contact me.
Best Regards,
tamsdon
*ISL55110 Spice Model
"* Revision F, Aug 2008"
* Delays now simulated with Delay Lines instead of RC Time Constants
* Models
.model SWOUTN VSWITCH ron=2.83 roff=100Meg von=+.2 voff=-.2
.model SWOUTP VSWITCH ron=2.6 roff=100Meg von=.2 voff=-.2
.model den D (n=1)
.model SWMOD VSWITCH ron=10 roff=100Meg von=+.1 voff=-.1
.model SWHIZ VSWITCH ron=100Meg roff=0.001 von=+.2 voff=-.2
* Components Definitions
*Input PAD
.subckt IN_PAD 1 2
RIN  1  2  100e6
CIN  1  2  1e-12
.ends
* Output PAD (IN GND)
.subckt OUT_PAD 1 2
RIN 1  2  100e6
* CIN should be adjusted  depending on the power down time.(PD time - 10 ns )
CIN 1  2  14e-12
.ends
*Comparator with hysterisis
*COMP_HS IN OUT VDD GND
.subckt COMP_HS 1 2 3 4
* Thresholds
VTHR1 7 4 1.2
VTHR2 8 4 1.4
* VDD/2 Generation
R1 3 9 100e6
R2 4 9 100e6
*Delayed output
R3 2 21 3e3
C1 21 4 0.43e-12
SW1 7 10 21 9 SWMOD
SW2 8 10 9  21 SWMOD
*COMPARISON
SW3 3 2 1 10  SWMOD
SW4 4 2 10 1  SWMOD
.ends
* Buffer Models ( IN OUT VDD GND)
.subckt BUF_X 1 2 3 4
*Generating VDD/2
R1 3 7 100e6
R2 4 7 100e6
SW1 3 2 1 7 SWMOD
SW2 4 2 7 1 SWMOD
.ends
*Level shifter (IN OUT LV_SUPPLY GND HV_SUPPLY)
.subckt LS 1 2 3 4 5
*Gnerating VDD/2
R1 3 7 100e6
R2 4 7 100e6
SW1 5 2 1 7 SWMOD
SW2 4 2 7 1 SWMOD
.ends
* Delay from LV(VDD) components in signal path
* LV comparator and level shifter give a delay of 3 ns(approx).
* T=0.69*R*C Obsolete, use delay line model instead
* Delay_LV IN OUT GND
.subckt Delay_LV 1 2 3
T1 1 3 2 3 Z0=100Meg TD=3n
R1 2 3 100Meg
*C1 2 3 0.43e-12
.ends
* Delay from HV inverters in the signal path.
"* though this delay vary with supply(VH) , modeled delay as 6 ns ."
.subckt Delay_HV 1 2 3
T1 1 3 2 3 Z0=100Meg TD=6n
R1 2 3 100Meg
*C1 2 3 0.43e-12
.ends
.subckt DelaY_HV-1 1 2 3
R1 2 3 100Meg
*C1 2 3 0.43e-12
.ends
*ISL55110 model
*      VDD PD IN_B  IN_A  OA VH GND OB ENABLEZ
.subckt ISL55110 1   2  3       4    5  6  7   8    9
XPAD_INB  3  7 IN_PAD
XPAD_INA  4  7 IN_PAD
XPAD_PD   2  7 IN_PAD
XPAD_ENZ 9  7 IN_PAD
*Input Clamp Diodes for IBIS
d5 7 3 den
d6 3 1 den
d7 7 4 den
d8 4 1 den
d9 7 2 den
d10 2 1 den
d11 7 9 den
d12 9 1 den
R1 1 99 100e6
R2 99 7 100e6
R10 6 199 100e6
R11 7 199 100e6
XCOMP_A  4 10 1 7 COMP_HS
XCOMP_B  3 11 1 7 COMP_HS
XDELAY_LVA  10 12 7  Delay_LV
XDELAY_LVB  11 13 7  Delay_LV
XLEVEL_SHIFTERA  12 14 1 7 6  LS
XLEVEL_SHIFTERB  13 15 1 7 6  LS
XDELAY_HVA 14 16 7 Delay_HV
XDELAY_HVB 15 17 7 Delay_HV
*PD or ENABLEZ
R3 18 7 100e6
SW1 1 18 2 99  SWMOD
*SW2 1 18 9 99 SWMOD
SWA 16 19 99 18 SWMOD
SWB 17 20 99 18 SWMOD
V  210 7 -1
R4 19 210 100e6
R5 20 210 100e6
* OUTPUT SWITCHES
*OA Switch
T1 9 7 230 7 Z0=100Meg TD=15n
R6 230 7 100Meg
SWTPA 6 220 230 99  SWHIZ
SWPA 220 5 19 199  SWOUTP
SWNA 221 5 199 19    SWOUTN
SWTNA 7 221 230 99    SWHIZ
C1 5 7 100pF
d1 7 5 den
d2 5 6 den
XPAD_OUTA 5 7 OUT_PAD
* OB Switch
*HIZ High Side
SWTPB 6 222 230 99  SWHIZ
SWPB 222 8 20 199  SWOUTP
SWNB 223 8 199 20  SWOUTN
*HIX Low Side
SWTNB 7 223 230 99    SWHIZ
C2 8 7 100pF
d3 7 8 den
d4 8 6 den
XPAD_OUTB 8 7 OUT_PAD
.ends
(3,896 Views)
Hi tamsdon,
Can you provide information about the error message you get when trying to load this SPICE model?
Jose F.
(3,891 Views)
Hi Jose F.
Thanks again for providing much appreciated assistance.
I am once again creating this component using the TOOLS->COMPONENT WIZARD. I have created simulation only model (no layout) and a schematic symbol with 9-pins as per the spice listing (see attached spice model .txt). I have also attached a .jpg file showing the error message that is displayed after I enter the spice listing into the component wizard at Step 5. The error message reads "Component Wizard Step 5 of 7: The model contains multiple top-level .subckt statements. Place any dependent .subckt or .model definitions within the main (top-level) .subckt".
Thanks again for your help.
tamsdon
(3,872 Views)
