Multisim and Ultiboard
Multisim - How ti Put a 8 segment indicator
Hi everyone...
I'm working on a example. I have to creato a 2 bit comparator, to comparate binary numbers:
                                  X=x1x0
                                  Y=y1y0
(1 and 0 is index)...
At the exit of comparator is an indicator with 8 segments. Depending on the report of the values that are being compared, in the indicator must be generated the symbol "<"...
Now my problem is the i can't and i don't know how to put a 8 segment indicator...
Also having some probs with the comparator, I'm not sure wich comparator to use....
Hope I'll find some help here...
thnx...
(3,560 Views)
I don't think you are going to get a pretty < out of a 7-segment display. A 15-segment, maybe. Also, if this is digital, why not just use gates? Unless you meant comparator as a fuction, not a device, AND gates are essentially comparators.
____
Ryan R.
R&D
(3,558 Views)
