Multisim and Ultiboard
Multisim Logic converter Help
I can't seem to get this to create a truth table based on the circuit I created, it just returns all zeros. What am I missing here?
(7,166 Views)
I fiddled with it and I can't seem to get the Logic Converter to do anything.  It would be nice if NI had some multisim sample files that used this.  They might have some, but help in multisim doesn't send you to sample files like help in labview does.
This is what multisim help looks like searching in the index
Now it looks like you have to grope around in the dark trying to make it work, I'd appreciate it if NI or someone else had a multisim file that used this feature.
I also have a project coming up that could use this feature.
Dave
(7,152 Views)
Well, i am late.
You need to connect the inputs at the first 8 pins of the logic converter, depending on how do you want the table. The output goes on pin 9.
(5,864 Views)
